usersmanual wrote:
I, and others, were only pointing out to the OP (and others, including you) that black tank chemicals (much like special rv toilet paper) is not necessary, nor required, and is only making your wallet lighter.
 Ron
But that's just your opinion and what you believe.its certainly not absolute fact like a few here try and spin
Chemicals in may cases are required, are necessary and do work very well
To each their own way of doing things
You like water then by all means use it.I think all natural chemicals are the way to go so I use them by choice
90% of the time my tank systems is perfect but like said take a 2/3 full tank and warm weather and stinky fumes will and do come out the roof vent.If u have the fan on input you can and will at one time or another get a wiff of unpleasant odours if not treated properly with a proper chemical.
as said to each their own. water works for some just not for me
forgot to mention another reason I use what I use is it breaks down the solids fast and therefore no worry of solids plugging up things
That is also YOUR opinion.....
My opinion based on 40+ yrs of RVng and FT living in an RV is chemicals are like an anode rod for an Atwood Water Heater....not needed BUT pose no harm
I don't use either and based on my own personal experience don't need either.
Poop stinks.......that doesn't mean it needs to be odor controlled...just control the odor by the built in designs----vapor barriers
You use and feel chemicals are necessary
I and as you see many others do NOT
As far as breaking down solids....water is effective and if you 'hold' waste until tank s full then dump the weight/volume f liquids will carry any solids out---the WHOOSH effect.
Like a fast flowing river moves boulders same with a full 'holding tank' (not septic where breakdown is needed). High liquid to solids ratio....WHOOSH
Continue as you see fit. Allow others to do so without turning it into an argument.   Debating is fine..but you are stuck on chemicals.
Personally I would rather smell natural poop vs chemical poop IF smelling of should poop happen (BIG IF---and if it can be smelled FIX the problem vs masking it)
You're wrong and I AM RIGHT. That's just the reality..........
:B:B:B:B:B
