AikenRacer's avatar
AikenRacer
RV Whisper
Last week, we lost power to our motorhome at the beach. The temp rose in the mh with our two dogs. Luckily we were not gone long and got the power restored. I am now looking at the RV Whisper system that sends me text alerts, etc if the temp in the motorhome rises. I have read some comments about it on this forum but looking for more pros and cons with this system from others who have used it. Thanks for any comments,
  • chuckftboy wrote:
    If you don't have auto generator start, its easy enough to add. Mine is set every time we set-up.
    Ditto. Installed the unit in 30 minutes and the wireless control module is on my dash. Great device.
  • If you don't have auto generator start, its easy enough to add. Mine is set every time we set-up.
  • I'm sure you have a generator in your motorhome. Do you also have automatic gen start? If so, there is a function that will cause the generator to start automatically if the inside temperature goes above your chosen set point. If you then also have your A/C set to come on, the generator will take over, even if there is a power failure, and run your A/C
  • Did you have your Auto Gen Start set to on and did you have temperature set up on it. I have mine set so if thermostat calls for cooling and no power gen will come on till coach cools down.
