NewRVerOH wrote:
Hello, hoping someone can help. I am going to have to start storing my RV (Class A Fleetwood Southwind) in an unheated storage unit. My issue is we use it in the winter for tailgating football games. Previously it was stored in a heated facility so it was never an issue. My question is I need to have water etc kept warm inside the new non heated unit. Should I simply run the furnace in the RV? Is that sufficient for keeping everything warm enough? Should I put a heater in the RV for while it is sitting in storage instead. I do not want any pipes to freeze, etc but winterizing is not an option as I use it for tailgating. Any help would be greatly appreciated.
Just use air - easy and Fast - Or you can leave the Heat on and fill the Propane after every game.
https://www.thefitrv.com/rv-tips/how-to-quickly-winterize-your-rv/Best of Luck from a former tailgater...............
