2chiefsRus
Aug 13, 2019Explorer
As others have already said, yes you can run one AC with the 30 amp. I see in your signature that you have several pets. I would want to stay around the coach for at least one afternoon before leaving your pets in the coach for an afternoon. Sometimes running on 30 amp can have a learning curve for those who are used to using 50 amp. It is easy to forget to switch the water heater to propane instead of electric, or the fridge may switch back to electric because it hasn't been run on propane for a while, etc. Best to work those things out before leaving the pets.
38,780 PostsLatest Activity: Nov 22, 2015
