DutchmenSport
Aug 13, 2019Explorer
We've run our 50 amp 5er on 30 amps a few times at campsites that did not have a 50 amp hookup. Power management is all you have to do.
If you have a gas/electric water heater, flip it on gas.
You can run one air conditioner, should be, with absolutely no problem, but not both at the same time.
To help save power management a little, if you have a gas/electric refrigerator, flip it to gas also.
If running the microwave, turn the air conditioner off while it's running. When done with the microwave, turn the air conditioner back on.
If running an appliance, like a 1500 watt hair dryer, or a 1500 watt electric skillet or griddle, run them on a completely separate extension cord plugged into the campground 20 amp socket (like in a house).
If you do these simple steps, you'll have no issues with power management. And you can run either air conditioner, just not both at the same time.
Folks do this type of power management all the time, successful on 30 amp with 50 amp RV's.
38,780 PostsLatest Activity: Nov 22, 2015
