CA_Traveler
Aug 13, 2019Explorer III
mowermech has a valid point. Let's assume the A/Cs draw 12A so that's 24A or exactly 80% of 30A which is the NEC recommended 80% maximum sustained load. Are their other loads?
Running multiple high draw appliances can be a **** shoot for those that don't or can't monitor the amps or the voltage. Most RVers are aware of burned or overloaded 30A pedestal plugs which can be due to both user and owner maintenance.
38,780 PostsLatest Activity: Nov 22, 2015
