prstlk's avatar
prstlk
?'s about AC, Electric in BR and and thank you!
We have been full time now for about 5 months and there are a couple of things that I need to ask questions about...
#1. When we are hooked up to power in RV parks there are no issues anywhere with any of the elecrical outlets.
When we are boondocking, however, neither of the 2 electrical outlets will work in the bedroom. Lights work and everything but not the outlets. I have to run an extension cord from the bathroom outlet to run my CPAP machine. Not a real issue but a little anoying.
Any ideas?
#2. We have 2 rooftop Dometic Duo-Therm air conditioner/heat pump units. The one in the living are works great. The one in the bedroom is the problem. When it starts out (and this is going to be hard to describe) it shoulds like it is having an issue getting up to speed on the fan. It almost sounds like the belt (or something) might slip a little then finally get going. Of course - it wakes us everytime it starts up. Have to have it though down here on the Texas coast right now.
I do not have an instruction manual for the units but they are both model #630035.331. I tried to find one online but no luck.
Any ideas on this one? Does anyone have any idea what maintenance these need to have done on them other than the filters cleaned?
Now the thanks!
We started having a bad sewer gas smell and - as usual - one trip through the search on this forum board yielded the answer - dry pee traps! We had been on the corn cob roads that are in the South Louisiana area and the one in the shower was dry. From now on every time we move one if the first things to do after setting up in a new area - water down all drains - including the shower!
Thanks to everyone who takes the time to answer my (and everyones) questions!
    Any ideas?
    I'm surprised you have power to the box in the bathroom - usually when you are powered up by battery the wall units do not work unless you have an inverter!
    here is your manual
    Now the thanks!
  • For the CPAP why not get a 12 volt CPAP if yours is not one in DISGUISE.
    There are a bunch of Duo-Therm manuals at
    http://bryantrv.com/docs.html#airconditioner
  • Hi,
    It sounds as if your rv is equipped with an inverter, but it is wired in such a manner as to not power all the outlets. It is becoming more common for RV's to have an inverter.
    It would be possible to move the outlet you need to the same circuit as the bathroom--but it might also mean having too many outlets on one breaker. Proceed with care.
    It is probably better to have a separate thread for each question.
