raymondfl's avatar
raymondfl
Sacrificial Magnesium pole for hot water heater
I have an Atwood hot water heater and I was reading about the chemical reaction in hot water heaters that causes rust. Now I do not understand this process but basically as I understand it I should have a magnesium bar that is slowly eroded over time. It is usually attached to the drain plug and inserts into the water of the hot water heater. But I have an Atwood hot water heater, not a Suburban hot water heater. I do not seem to have this part, and no where in the manual can I find any info on one. Does anyone know if I should have this sacrificial lamb in my hot water heater. If it sounds like I am not sure what I am talking about you are correct. Any help??
Thanks
