I fortunate to have the coach at the homestead so winter time is for projects. This winter is power train maintenance (engine coolant and differential oil change) and interior deep cleaning. Might redo the fresh water plumbing to replace and add additional low point drain valves. Current valves are behind a panel under the vanity sink that doesn't like to be removed. If there's still time I want to rewire the fridge 120VAC circuit which is currently shared with the most commonly used outlets. Adds an extra step to switch the fridge from auto to gas when I switch in a low wattage inverter.
