Rich D. wrote:
While I agree wholeheartedly with the posts recommending a full time protection device, the OP asked about checking the power before plugging in. The devices mentioned will protect from many power problems but a suspect outlet should be tested before even plugging in your protection device.
You're absolutely right. My PI unit does check the pedestal before supplying power to the RV. If there's a problem, it will display the appropriate error code so I can tell the office what's wrong. I consider ANY outlet suspect until I've tested it.
