I have a 2018 Gulfstream Conquest 6320. The weight of the platform on this very long slide(dinnette booth and sofa) has pulled the back rest of the dinette from the wall and the middle of the platfor...
I would go outside an check the gap at the top of the slide to the side wall when the slide is almost in. If it is greater that the bottom gap there is an adjustment on each end of the slide to correct that. Also check underneath the slide and look at the bottom of the slide to see if the rollers have worn a grove into the bottom of the slide. This will also cause your slide to sag.
