ljr
Feb 07, 2016Nomad
bluwtr49 wrote:ljr wrote:
I have a Winegard Trav'ler and Dish. I like both but not together. If you go with a Trav'ler, get Direct. The Trav'ler has limitations with the Dish satellites. Depending on your travel and viewing habits you may not care but since you're starting from scratch you might as well just avoid the whole issue.
What are the limitations with Dish you spoke of?? Granted sometimes 129 can be difficult but that only means no HD on some channels.
Long complicated explanation but the short version is that it can't get all the Eastern Arc satellites at once. If if you don't care about local channels via satellite and major networks (ABC, NBC, CBS & FOX) then it doesn't matter. If you don't spend much time in the east then it also doesn't matter. In AZ it isn't an issue.
If your starting from scratch, might as well get Direct and avoid having to figure out what all that means.
38,782 PostsLatest Activity: Sep 10, 2026
