- Looney2nzExplorerMan this is some good stuff guys. Havent got the sgII yet, is in the mail and should get it tomorrow. Yahoooooo
- KristinUExplorer
shawdowboss wrote:
When we figure it manually, we ignore the small amount the generator uses. We have an 80gal tank, so when filling 50+ gallons, 1-2 gals from the generator is a small drop in the bucket. We just note GEN in our tracking book to show it was used.
On the SCANGUAGE, you could tweak the fill, but I would try to avoid using the generator on the setup for the MPG function (takes 2 tanks). This way it will calculate the MPG correctly. Most use the fuel usage to calculate the MPG, it just needs to get calibrated so it knows what it's seeing from the vehicles ECM.
Great, good to know on the calibration, thanks! We are about 50/50 on dry camping vs. hooking up, so the genny will get some use with us, at least to re-charge the batteries every few days when no hooked up to shore power. Our fuel tank is 55 gallons, so it might show a little. - shawdowbossExplorerWhen we figure it manually, we ignore the small amount the generator uses. We have an 80gal tank, so when filling 50+ gallons, 1-2 gals from the generator is a small drop in the bucket. We just note GEN in our tracking book to show it was used.
On the SCANGUAGE, you could tweak the fill, but I would try to avoid using the generator on the setup for the MPG function (takes 2 tanks). This way it will calculate the MPG correctly. Most use the fuel usage to calculate the MPG, it just needs to get calibrated so it knows what it's seeing from the vehicles ECM. - KristinUExplorerWe just took our maiden voyage in our new-to-us 2008 Winnebago Chalet (Ford E-450 chassis) and were talking during the drive about getting a ScanGuage II. One question that we discussed: is there any sort of accomodation or override for generator use when it figures out MPG since the genny fuel comes from the vehicle fuel tank? (or likewise, how would you manually figure that out of your MPG if you're keeping track on paper?)
Cheers!
Kristin - Just_LeeExplorer
eric1514 wrote:
Looney2nz wrote:
Just Lee what a PM? I'm kinda new,sorry.
Look at the top right hand corner of this page and you will see a "Private Messages" (PM) link. Click it. He left you a private message so you two can communicate with each other outside of this thread.
Eric
Thanks Eric.... - eric1514Explorer
Eric - Looney2nzExplorerJust Lee what a PM? I'm kinda new,sorry.
- Just_LeeExplorer
Looney2nz wrote:
Sorry to change the subject but Just Lee how are you going to hook up your tail/running/turn lights from the MH tothe96 Tracker? I have a97 I'm going to tow. Thanks
I'll send you a PM... - Looney2nzExplorerSorry to change the subject but Just Lee how are you going to hook up your tail/running/turn lights from the MH tothe96 Tracker? I have a97 I'm going to tow. Thanks
- Just_LeeExplorerAH ha CEL= Check Engine Light..... See I'm learning... LoL
38,782 PostsLatest Activity: Sep 10, 2026
