j-d
Jul 22, 2016Explorer II
I've seen one of the screws that holds the choke or throttle plate of a mower carburetor falling out and being sucked into the engine's intake. Luckily, the intake valve in that particular engine didn't open far enough to let the screw into the cylinder. It only held the valve open so the engine quit for no compression.
If the ONAN had the air filter in place, the carb would be the only source of small screws. Pack Rat that I am, I looked at an ONAN Micro (4KY) carb. There are two screws in the choke plate and two in the the throttle plate. I think your carb has three or less screws still in place.
38,766 PostsLatest Activity: Jan 10, 2026
