bleesr's avatar
bleesr
Seal between Cab and box
Hey guys. I'm new to this forum and new to RV'ing. I recently purchased a 1999 Fleetwood Tioga with significant water damage to the cabover section. I'm a handyman and have decided to do a major renovation on it. I have removed the the bottom steel frame and the divider walls because the frame was rusted through and the walls were literally completely rotted away on the bottom and sides. Anyway, when I removed the walls and steel frame, there was a foam gasket between the cab and the walls. It is a neoprene type gasket with double sided tape on one side so it would stick to the cab. In retrospect, I wish I had been more careful to salvage it. It is a white foam tape, about 1" wide, 1/4" thick (original thickness). I have asked Fleetwood for information, but the original manufacturer is no longer in business, so they don't know. Does anyone have any idea what this stuff is and where I can buy it?
Thanks!
  • "Bob's your uncle" is a way of saying "you're all set" or "you've got it made." It's a catch phrase dating back to 1887, when British Prime Minister Robert Cecil (a.k.a. Lord Salisbury) decided to appoint a certain Arthur Balfour to the prestigious and sensitive post of Chief Secretary for Ireland.
  • bleesr wrote:
    gkainz wrote:
    photos and a rebuild thread would be great to follow along on your progress. Or relive the horrors of the last time I did it about 10 years ago! (Kidding - it wasn't THAT bad but I got twisted up with time constraints of my own doing).
    Sounds good! I've taken a lot of pictures and videos. I may post it to my YouTube channel. How do I do a thread on here?
    same way you started this thread ... open a new topic, give it a descriptive title and away we go! Or, as my Aussie friends say "Bob's your uncle!" never have figured out exactly what that means but I guess it makes as much sense as "piece of cake!".
  • photos and a rebuild thread would be great to follow along on your progress. Or relive the horrors of the last time I did it about 10 years ago! (Kidding - it wasn't THAT bad but I got twisted up with time constraints of my own doing).
  • Yep, Home Depot has it. Comes in gray, white, black. If it's not in your local store, check their web site.
