Sandra's avatar
Sandra
Sealand toliet
We have a Sealand traveler China toilet.
Had the floor flange seal replaced, hand held hose replaced,water valve,and flushing pedal replaced. It still leaks from the bottom.
Any ideas.?
Getting expensive.
Double post
See other thread running
Admin
RV.net
1 Reply
  • Bowl/base seal band clamp loose
    Vacuum breaker leaking
    Cracked bowl
    Place some toilet paper around hose connections, around vacuum breaker, around base, around any area you suspect.
    TP is a great visual for IDng leaks
    Manual
