TCI's avatar
TCI
need help with flush ball on sealand 110 toliet
Our toliet doesn't hold water and after cleaning and troubleshooting, we are replacing the teflon and rubber seal kit part# 311462. Now, the flush ball should also be replaced part# 310954. We can't figure out how to remove the old flush ball without taking off the entire toliet base which we dont' want to do. We have replaced the flange and if we take the toliet off the flange will break again and it's nearly impossible to get it back on. I have googled for instuctions but can't find any that really give good information. Just remove the seal and then the flush ball and replace it. So were frustrated. Any help would be greatly appreciated. As always, thanks for the help.
  • Where do you get this tongue drpressor thing?
    Our toilet owner manual mentions using their seal cleaning tool but RV didn't come with it, dealer we bought from never heard of it, neither did the several other dealers we've been to for other stuff, nor Camping World, nor Amazon.
  • Fill it about 1/2 full with vinegar let set over night. That solves the problem about 75% of the time.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Short story, Had to do it on my same model toilet.
    And yes you have to remove the entire toilet.
    Some good news
    You do not have to disconnect the water lines from the valve
    You remove the part that sends the water into the toilet (This includes a vacuum breaker which is under the "HAT" like piece of plastic at the rear) and remove 2 (As I recall) screws and the valve comes off intact,,, (You can also remove the flush lever and you do have to remove the lever cover first)
    Then 4 bolts to remove teh toilet and turn it upside down (Outside)
    or loosen the band lift off the bowel and 4 bolts to remove the pedistal.. The job has to be done from "Below" Gloves suggested
    From this point.
    you remove a screw in teh ball
    you remove anotehr screw in the spring assembly
    you remove the spring assembly
    Tap the shaft into the toilet and remove it
    Remove the ball
    Re-assembly is the reverse
    IF you have an orignial plastic shaft the new ball should come with a brass one USE IT.
  • I read on another post that someone's toilet was not holding water and they put plumber's grease on it and it fixed it.
    I did the same and now mine is fixed and holding water:)
    I put a liberal amount of grease on the seal, let it set a couple days with no water in it. Went on a camping trip, it leaked a little, so I took off excess grease. After a couple days of using the toilet the seal is working fine.
    Try this before you take the whole toilet apart.
  • Good post. Ours is not holding water, used the tongue depressor thing to clean it but still doesn't hold water.
    We need the same fix.
  • You have to pull the base from the floor flange to change the ball.
    I highly recommend you get the ball, shaft, spring kit for completing the job.
  • I have the exact same model toilet & the ball quit working but luckily it was stuck in the opened position. Since we were taking 2 planned trips with only 2 days between them -- we just used the toilet anyway.
    When we got home & I could finally take the toilet apart, I loosened the silver band holding the top on the bottom. I used the ball-cleaning tool (AKA "tongue depressor") and an old toothbrush on the ball, & scrubbed off the 2 seals. Then I applied a good amount of Vaseline to the seals and surfaces of the ball & reassembled the toilet.
    Voilá! The toilet worked again. Except...... It still won't hold water. Not a problem with doing #1; a problem with doing #2. So my son came up with the idea to lay a couple of strips of TP in the bowl before using & everything flushes down just fine! Maybe even better than before since there's no "skid marks" in the bowl even!
    Just sayin' that the lack of water in the bowl hasn't affected our use any. And I don't notice any odor coming up either, since the ball pretty much covers the opening.
  • You can separate bowl from base by loosening/removing bowl/base clamp.
    You will need to disconnect supply hose from water valve OR vacuum breaker so bowl assembly can be lifted up and moved out of the way.
    Exploded view of toilet..........LINK
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
