wa8yxm
Sep 20, 2014Explorer III
TCI wrote:
Our toliet doesn't hold water and after cleaning and troubleshooting, we are replacing the teflon and rubber seal kit part# 311462. Now, the flush ball should also be replaced part# 310954. We can't figure out how to remove the old flush ball without taking off the entire toliet base which we dont' want to do.
Short story, Had to do it on my same model toilet.
And yes you have to remove the entire toilet.
Some good news
You do not have to disconnect the water lines from the valve
You remove the part that sends the water into the toilet (This includes a vacuum breaker which is under the "HAT" like piece of plastic at the rear) and remove 2 (As I recall) screws and the valve comes off intact,,, (You can also remove the flush lever and you do have to remove the lever cover first)
Then 4 bolts to remove teh toilet and turn it upside down (Outside)
or loosen the band lift off the bowel and 4 bolts to remove the pedistal.. The job has to be done from "Below" Gloves suggested
From this point.
you remove a screw in teh ball
you remove anotehr screw in the spring assembly
you remove the spring assembly
Tap the shaft into the toilet and remove it
Remove the ball
Re-assembly is the reverse
IF you have an orignial plastic shaft the new ball should come with a brass one USE IT.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
