Fastpaddler wrote:
The Gearspace 34 weights 120 lbs and can carry 380 lbs max. Many people use them and although they are a tongue weight factor they can be used. I have one.
I have the GearSpace 20 when I quoted my example. Just because the carrier itself can carry such a load it does not mean the vehicle itself can. In fact the Gearspace 34 was designed primarily for carrying two bicycles under secure cover which most likely would be under 100 lbs total. If you filled it up with 380 lbs which I think would be difficult to do unless you were hauling construction materials or your barbell set, I know a T1N Sprinter could not handle it. Your front wheels would be practically turning in air and if still on the ground would be horribly squirrlily.
