- deadbatExplorer
Sully2 wrote:
jurzbill wrote:
Call cummins or any cummins dealer, they will tell you, then buy online. this is where I got mine:http://www.ryderfleetproducts.com/ryder/af/ryder/core/content/product/srm/oid/51229/pn/belt-8-rib-1-1-8-wide-x-69-long/erm/productDetail.do
Cummins cant help. They dont know what sort of belt driven garbage the coach maker hung on the engine.
Call the company that made the coach...they sure ought to know
Your post quote;Cummins cant help. They dont know what sort of belt driven garbage the coach maker hung on the engine.
your 100% incorrect.Give a engine serial number to cummins or a cummins dealer and they will most certainly give you a CORRECT belt number.Been there and done that. Coach makers dont "hang" garbage on a cummins engine.its a single serpentyne belt
Its a rolling chassis most likely freightliner or Sparton - RedGExplorerThe number should be on the belt. Have you looked?
I bought a Gates Greenstripe from " wolfco1 " on ebay for less than $25.
The belt for my Cummins ISL is a K080702HD. - WILDEBILL308Explorer II
Airstreamer67 wrote:
If you do change it out because of preventative maintenance, be sure to keep the old one for potential use in getting home some day.
I would throw that old one away and get a new one for a spare. Why go through all the trouble to change it with one you didn't trust to begin with.
Bill - Sully2Explorer
Call the company that made the coach...they sure ought to know - jurzbillExplorerCall cummins or any cummins dealer, they will tell you, then buy online. this is where I got mine:http://www.ryderfleetproducts.com/ryder/af/ryder/core/content/product/srm/oid/51229/pn/belt-8-rib-1-1-8-wide-x-69-long/erm/productDetail.do
- barnaclebillExplorerMine was $38 bucks, just installed it last week
- p0ochesExplorerMy serpentine belt broke, because my alternator seized, and it tore up the fan in the process of flying around and out. Cost me 1200.00 to replace the alternator, fan, and belt. A lot of that was labor because replacing the fan is very time consuming, since the shroud is in the way. Doug 2003 Winnebago Journey 330 Cat
- Airstreamer67ExplorerIf you do change it out because of preventative maintenance, be sure to keep the old one for potential use in getting home some day.
- FishinghatExplorer IICall a NAPA store and give them the number. I bought a spare a number of years ago, and I remember it wasn't cheap, but a whole lot cheaper than being stuck without a spare in the middle of no-where.
38,782 PostsLatest Activity: Sep 10, 2026
