ronfisherman
Apr 07, 2015Moderator
Check the propane orifice to make sure it is not blocked. You can remove it and soak it in alcohol for a few minutes. Then blow it out with low pressure air. Reinstall. Should hear a kind of roar when burner is operating properly. But not as loud as water heater.
38,780 PostsLatest Activity: Jul 04, 2015
