kemer
Jun 02, 2015Explorer
Set up Order
Is there a preferred order when setting up? I read that the unit should be level before extending slides. So I've been doing the auto-leveling first, until the monitor says "success" and is level. Then extending the slides. I've found that after extenting, the unit tilts slightly to the left(where I have two slides). Would I be better off extending slides first, then running the auto-level? I realize that the most important thing to have level is the Refrig. I'm guessing that if the site is basically level, extending the slides first, then leveling should work.
THANKS.....
THANKS.....
