Engineman113ExplorerDec 19, 2017Setting upBrand new RV’er when i arrive at a site with a Class A MH Do I 1 level the rig with the stabilizers then deploy the slide out 2 deploy the slide out then level the rig with the stabilizers ...Show More
wolfe10ExplorerDec 19, 2017Yes, it is not about arguments or which is right-- the right answer is what your coach engineers designed into YOUR coach.Even if it is different than the coach someone else owns, it is correct for YOURS.
