jfkmk wrote:
holstein13 wrote:
chiefneon wrote:
X2 regarding the Sewer Solution. We've been using the same one for over 15 years without issues. I purchased a second on a couple of years ago simply because our new TH 5er has two 3" dumps on it.
X3 on the Sewer Solution. It's always clean (relatively speaking), no smell and easy to store. The only downside is it's sloooooow.
So what's the advantage of sewer solution other than longevity? $133 for sewer solution on Amazon v $24 for Rhino Flex. My rhino flex is 5 years old and showing no signs of wear. Even if I had to replace it today, I'd have to go through 5.5 rhino flex hoses (or 25+ years worth) just to break even buying a sewer solution. I've had no pr lens using of storing my rhino flex, so I would ask what is the advantage? Not being antagonistic, just curious.
The advantages are:
- Easy to store
- No smell
- Self cleaning
- Can pump sideways
- Extensions are small and easy to carry
- Doesn't require a hose support
- Nozzle redirects to rinse out sewer outlet
- Has a clear attachment to outlet to see when done
The disadvantages are that it's super slow, it's costly, and it requires a water source.
