two_travelers's avatar
Jun 13, 2016
Sewer hose replacement
Well, it's time for a new sewer hose. Looking at the new Thetford titan premium or Rhino flex. Prefer one with end caps to keep water in and 2 10'sections as most time 10' is enough. Any recommendations would be appreciated. Thanks to all who share their knowledge.
  • Howdy!
    X2 regarding the Sewer Solution. We've been using the same one for over 15 years without issues. I purchased a second on a couple of years ago simply because our new TH 5er has two 3" dumps on it.
    "Happy Trails"
    Chiefneon
  • Add us to the Rhinoflex list, although that Smart Hose looks pretty interesting.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I used Rinoflex for two wear out cycles now have the Tethford "Smart Hose" and really like it.. It is different.. Sewer Master or Drain Master (forget which) is the best (And most expensive) but it is the last sewer hose you will ever buy (Lifetime warranty).
    What am I using now: The one the dealer tossed in for free 11 years ago.. I do not often use it, but on this site it is the EXACT length I need, no other hose in the RV can say that.
    Page 2: Sewer Solution.. This device is a fresh water powered Jet/Macerator pump.. Water is becomming more and more scarce, plus in some states, the water is all owned by a company such as Nestles or CocaCola. I can buy Coke's bottled water just 3 miles down the road for a mear 12.80/gallon... Thus I would rather not place the added load on the park's sewer system or water supply by using the Sewer Soultion.
    Electricity in this country is plentiful, plus many RVers use solar panels to soak up a few hundred watts of sunlight.. Flo-Jet makes a portable macerator pump, electrically driven.. Works great, Works even better/faster/farther/higher than the sewer soultion, It has only one problem easily overcome (The rotor sticks if not used for a long time, they provided a slot in the other end of the motor shaft you can turn with a quarter or screwdriver to free it before you apply power).
    I like mine. I added 50' 3/4 inch black rubber hose for the long runs to the hole in the ground. Works great.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
  • I like the cheap brown ones because they take up much less space in storage. I find we get about three years use and we are out about five months.
  • We use the Sewer Solution, best purchase we have made! No more stinky slinky.
    Cost a little more but will last much much longer!
    Good Luck
  • We've had good success with our Rhinoflex also, wife even drove over it once, left a small flat spot but did not tear. Replaced one end after she she ran it over as well. We have e 15' and two five foot sections.
  • jfkmk wrote:
    We've been using a Rhino Flex for five years now and have had no issues. Not really expensive either.
    X2 These are really good. They do their job. :)
  • We've been using a Rhino Flex for five years now and have had no issues. Not really expensive either.
