Here's how I enlarged the short sewage hose compartment. I cut off the existing compartment and added a length of PVC drain pipe with flared end to slip over the shorten compartment. I wedged the end of the pipe over the frame rail. Had to cut the end at an angle to fit over the frame. I used PVC cement to glue the pipe in place. I drilled a few drain holes in the pipe.
Mike
