Hotdog99ExplorerJan 15, 2017sewer line brokenI have a sewer line that is broke where the waste valve bolts on I have to re place that part and it is glued how do I get it to turn loose
Bill_SatelliteExplorer IIJan 15, 2017Are you sure? Can you post a picture? There are usually pre-made assemblies that connect the tank to the valve. You may just need to replace the entire assembly and not where you see the leak.
Related ContentShould I connect my sewer line when camping?frozen sewer hose and water lineSewer line PVC supportsWiper Fluid in Water linesSEWER LINE AND WIND RESISTENCE
