I assume you have looked underneath and there are no drips revealing a leak. In my 2016 winnebago the washer was plumbed to black tank. The entry to tank was low-too low- and it would backup leaking a bit where the hose went into the drain. Once i figured out problem-smell-the fix was easy. Never do laundry without black tank valve open. A long shot but you might open areas where a tank or pipe could leak and let your nose guide you. For me small back flow just soaked. Took a major for me to discover and then a lot of gloves, paper towel and bleach. Traded for a DP.
