putzinaround's avatar
putzinaround
sewer smell in rv
We have been traveling south with our 40' Newmar Mt. Aire for 5 years. This is the first year we have experienced a sewer smell inside the RV when the air conditioners are on. First thing we check is the gas stove, but that isn't it. My husband usually connects the sewer hose, but closes the drain on the sewer and gray water and only dumps when needed. We have done this for years without a problem. We have dumped water down the stool and drains, but hasn't helped. Also, have added some liquid smell deterent, but it doesn't help. Any idea what is going on? When the air goes off, it's gone. Why now and not before?
  • gbopp wrote:
    Did you check the air admittance valve under the sink(s)?
    That's the most likely answer for your situation. AAV's are readily available at home improvement stores, and don't cost a lot.
  • Have you checked/ replaced the filters on the A/C? You may have something setup that is creating a low preshure in the coach pulling air back through the traps.
    Bill
  • Did you check the air admittance valve under the sink(s)?
