tnmotonana's avatar
tnmotonana
Sewer Smells
We are new to motorhoming and need to hear from the experts! We have had a pull behind for years.
So my question....When we dump the smell is horrible inside the coach. I dont know if we are doing or not doing something right. We use the tabs/or liquid while parked and smell nothing, but the minute we dump the black tank it will almost make you sick. Please help
  • I'd check the ball valve seal on the toilet first thing. Second, sometimes the bathroom sink is plumbed to the black tank... and it usually has an air admittance valve. That is likely shot, so replace it, or if one is a plumber, replace the trap with a HepVo waterless trap, which not just keeps smells from coming out, it allows air to come in the drain to equalize pressure.
  • I recommend you dump - refill with water and dump again. If you use a solution that doesn't work well try RIDX fro RV! We did and it is super!!
    Hoppy dumps and sorry for your troubles. :E
    p.s. I suspect there is **** left over from each dump and RID-X for RV will help.
  • Do you keep water in the toilet bowl?
    There's only two ways this can happen, the smell is coming thru the toilet but if you have water in it I would rule that out and two... thru the vent pipe on top of the Coach. Perhaps if you have a fan or the A/C running your sucking that perfumed air inside?
