xctraveler's avatar
xctraveler
Shift Inhibit and a crash
I am cross posting from Tiffin Network since this could have been far more tragic.
I will accept that this was an anomalous occurrence. Unfortunately it resulted in the coach hitting 8 cars and essentially destroying the front end.
I pulled into a parking lot and found that there was insufficient room to complete my turnaround. I got out to guide my wife in maneuvering through the lot - this is not an uncommon behavior for us, in tight quarters I will guide and she will drive. She has over 100,000 miles over 15 years driving our coaches. When she attempted to engage D the dash lit up with "shift inhibit" and the shift panel went dark. Instead of shutting down she tried again and the engine revved and the coach jumped forward hitting 8 cars before stopping.
The great news is no one was injured, not even my wife. I was standing just enough off to the side to avoid getting hit myself.
My question is has anyone else experienced an issue with shift inhibit and subsequent loss of control? FL has declined to inspect the coach unless my Insurer insists. I will let it drop unless I hear about other instances even if no damage was done.
  • This is what causes shift inhibit
    The following conditions may cause an inhibited state:
    Engine speed too high
    Throttle percentage incorrect
    Output speed movement
    The transmission control system inhibits shifting to protect the transmission
    from some types of abusive operation, in response to Diagnostic Trouble
    Codes (DTCs), and to satisfy transmission feature/option requirements.
    These shift inhibits fall within the following types:
    Above idle neutral to range shifts
    Forward/reverse directional shifts
    Transmission problems
    Auxiliary equipment operation
