papakilo42's avatar
papakilo42
Shore GFI opens when RV is plugged in to it.
I have a 2004 Coachmen Leprechaun 292. Opens the shore GFI. The shore GFI operates fine with tools and other loads. Just reacts to the RV. Coach circuit breakers in off position, A/C off. When the Onan/Cummins Generator is ON Line all Coach circuits operate normally, including the A/C. I am a novice at troubleshooting RVs without wiring diagrams and specific information concerning the Energy Conditioner unit, ATS #032-00061 opt. G, Gen time-out circuit for the ATS, and what voltage/resistance/continuity measurements I should see at various connections. Where is the rectifier/diode for the ATS coil? I have been in the electronics/electrical fields for over 50 years and have never worked with RVs or not been able to obtain wiring diagrams.
Any assistance or wiring diagrams will be appreciated.
Additional Info: RV has been connected to a shore GFI for 5 years, without problems. Operation of GFI: It senses a difference of potential between Ground and Return of shore lines. The generator cannot have the Return and Ground leads connected. The generator A/C lines are normally disconnected by the ATS in Shore Power use.
  • If the RV trips a GFCI it's because there is a problem. Don't just plug it in to a non GFCI recept. Fix the dangerous problem - which is probably a bad heater in the fridge.
  • GFCI should not be use to power an RV. The AC refrig and water heaters are prone to causing the GFCI to trip. Change to a non-GFCI receptacle. JM2¢...
  • Your coach should be wired as a secondary panel. I.E. The ground and neutral should be isolated from each other. Some where in your coach, the ground and neutral are bonded together. Find and un-do that bond and your GFI problem will go away.
    Richard
