GrumpyandGrandm
Aug 06, 2013Explorer
jtcpartners wrote:
I have a 2008 37' Jayco Seneca MS 38 Class C diesel with Chevy 5500 Duramax with Allison transmission. Good idea about using the tester. I really appreciate all these tips! I crank and run the engine for 5 minutes or so and not longer. I do take it for a drive at least once a month but try and go camping more often so it doesn't sit idle long. Can't wait for Aug. 30 for out 1 month trip west!
The TV won't operate while you are driving unless the previous owner disabled the saftey disconnect. There is a purple or red wire going to the back of the TV outlet, if you cut or disconnect that wire the TV will function while the engine is running. If you have the 1,800 watt inverter the only 3 items that work off the inverter are the microwave and the 2 TV's, if you have the 400 watt only the front TV works.
Also it is not recommended to run the engine unless you let it get to operating temperature. Short cycles build up too much moisture in the oil.
38,708 PostsLatest Activity: Mar 05, 2025
