MrWizard
Jun 27, 2016Moderator
goto your 120v breaker panel
turn all breakers off including the MAIN 50 amp double pole
then start with the main
and turn the all on one at a time
that might take care of some of your 120v like the WH and fridge
if not
go outside that to the power Pedestal and turn the main 50a breaker there off then on to reset it
make sure you push all the way OFF, feel for the click, when it goes off and On
check your inverter charger for blown fuses, and the DC fuse panel for blown fuses
also check your battery disconnect switch
it might have failed or it might have been inadvertently activated
if not
38,777 PostsLatest Activity: May 24, 2026
