ALAIN_'s avatar
ALAIN_
Shoreline RV5036
Hi.
I'm new on this forum.
Question:
- Does someone have an idea of the electric wiring plan, I dont know where each wire is attach.....???
Many thanks for your help.
http://qnapnasx70pro.myqnapcloud.com:8080/photo/slideshow.php?album=rljlSv
  • Yep.....
    I found by myself.
    On the reverse side of this part, you have 3 rings.Those rings turn on 3 terminals in the box. In that box, you can see the color of each cable.
    On the picture, il we begin by the left:
    First: White
    Second: Red (near the middle)
    Third: Black ( upper)
    The last one we can see: Ground.
    Change the rivet by screw and that's it, it work like new.
    Have a good day.
  • Alain, Welcome to the forum:
    In the future;
    1. Go to Advanced posting.
    2. Click on the small blue icon next to the "quote" marks.
    3. Follow the instructions provided.
    Your post will then look like this....
    ALAIN_ wrote:
    Hi.
    Question:
    Clicky
    Follow Doug's advice above....Dennis
  • Hi Doug.
    Many thanks for your reply.
    I will try .
    Have a good day.
    Alain
  • I KNOW that part (electric 50 amp cord reel internal connections), but cannot tell you where the Black/Red/White connects too. When I get that part in the shop, the ONLY logical thing to do is replace the Cord Reel assbly. But, if you insist on repairing. You can connect the White/Red/Black to any of the open ring terminals. ALL you have to do when connecting the 50 amp cord is to verify that the White/Black/Red/green(ground) is to the correct pins on the 50 amp end. Red and Black are interchangeable. Doug
  • Hi SeaDog/BRR.
    Take a look to the link. If you know this part, you probably can help.
    This photo explain the problem.
    Thanks, have a good day.
  • When you post give the reader enough information (background) that they might be able to help you out. Your msg is very vague;
