pnichols
May 22, 2017Explorer II
Kathryn (the OP),
I recommend looking for a used one of these in the 24V (24 ft) model, even if you have to go to another state to pick one up: https://winnebagoind.com/resources/brochure/2006/06-Outlook-bro.pdf
This model features such things as:
- One piece fiberglass roof with the entire length of both sides edges rolled over for long term roof joint leak protection
- 38 cu. ft. of exterior storage, including two long storage areas running across the coach under the floor for long items such as beach umbrellas, shovels, fishing gear, etc.
- 43 gal. of fresh water capacity
- 29 gal. of grey water capacity
- 39 gal. of black water capacity
- 18 gal. of propane capacity
- 55 gal. main engine fuel tank, for a cruizing range of around 500 miles
- a full size spare tire on a rim with a nice place to store it out of view
- a chassis that can be serviced "anywhere in the U.S." (Ford)
- weather band radio in the cab
- emergency switch in the cab to connect the coach battery(ies) to the engine battery or the engine battery to the coach battery(ies)
- switch in the cab to power the cab radio from either the engine battery or the coach battery(ies)
- remotely controlled and heated cab mirrors
- built-in generator that is installed properly so it's not very loud inside or outside to comfortably run for hours when air conditioning is needed
- propane oven instead of a convection oven so you can bake a pizza (or other stuff) without hookups or running the generator
- room for two large batteries in their intended storage cabinet without sacrificing one of other storage areas in order to add a 2nd battery
- a widebody design so a slide is not needed for a roomy feeling inside, thus eliminating slide problems over time
- good ground clearance to help prevent any scraping of the coach outer walls or undercarriage, including coach outer walls that immediately start sloping upwards starting right at the rear fender well to help prevent scraping when entering/leaving parking lots or crossing road washouts
- large storage areas at both the head and foot of the cabover bed due to the widebody design
- tall outside storage cabinets due to this being a Class C with a "basement" design
- a large engine alternator and good engine/coach charging circuit design so that the coach batteries charge up well and fast when on the road between camping sites
- several distributed and adjustable ducts for the propane furnace
- several distributed and adjustable ducts for the air conditioner, the air conditioner fan has two speeds
- the furnace and air conditioner are controlled with an automatic digital control
- there is a built-in floor light for night trips to the toilet or for use as a nightlight
- a full standup shower and the freshwater capacity to actually be able to take good showers without needing to be on hookups or feel that you must use only campground showers
- heated black and grey tanks for cold weather camping (an option that may not be on a used unit)
- dual batteries instead of only one battery (an option that may not be on a used unit, but a 2nd battery can be easily added)
- outside shower for pets and/or humans
- built-in provision for winterizing during storage in cold conditions
- outside entertainment center for music or TV/movie watching on warm evenings
- detachable outside platform that doubles as a TV table or small BBQ table
- built-in surround speakers for the cab radio and DVD player
- interior sleeping beds for six(6) adults, 4 spots are permanent and 2 spots have to be quickly set up for each use
- all exterior sewer and electrical equipment resides in enclosed cabinets up high so there is nothing to get hung up on rocks, logs, gas station islands, etc.
- plenty of galley counter space due to a built-in fold out counter extension plus a cover for one-half of the double sink
- three burner stove instead of the more common setup of only a two burner stove
- built-in water filter for the galley sinks
- hardwood cabinets with solid doors
- steel drawer slides
- vinyl flooring in the galley area and carpeting in the dining and loung areas
- huge storage under each dinette seat because the room is not taken up by a water heater, propane furnace, etc.
There are more points I could list .... but the above provides an idea what they came stock with. Winnebago abandoned this length with this floorplan and set of features on the rugged E-Series Ford chassis in 2006. However, you must consider at least a 2005 in order to get the better computer controlled 5-speed TorqShift Ford transmission with it's outstanding Tow/Haul mode for maximum safety and minimum brake wear when driving in the mountains.
We have a 2005 version (24V Itasca model - still built by Winnebago) of the above that we bought new and (still) love it. It's small for easy driving and camping in the small, older car/tent campsites found in County, State, and Federal public lands ... yet it has all of the comforts of home for use in campgrounds with hookups or for use in campsites out in the middle of nowhere. We take ours carefully off-pavement and can get to and camp many places where Class B motorhomes and truck campers can - but with more room and comforts when we get there. i.e. We can wash and dry the dog using the exterior shower and built-in generator way out there in the boonies. :)
