- dbhhcolorExplorerThe Alabama coach was used by a Auburn fan for football games. Sorry guys, can't root for Alabama or Auburn-Nebraska fan all day long.
Anyways, it appears to be well cared for. I will visit in a week to verify. - 2gypsies1Explorer III
hypoxia wrote:
The front and rear clear coat normally starts peeling around ten years. I painted the front cap on mine 2 or 3 years ago and the back is doing it now.
If the RV has had good care and waxing, it's not going to peel. There are some beautiful ones out there over 10 years. Ours was one of them. :) - hypoxiaExplorerInside or under cover is an advantage. The front and rear clear coat normally starts peeling around ten years. I painted the front cap on mine 2 or 3 years ago and the back is doing it now.
What vintage are you looking at? The Revolution is well built and you have the advantage of American Coach customer service which is top notch.
They were built on Freightliner and Spartan chassis and just like the old Chevy-Ford-Dodge argument everyone has their favorite. Mine is on the Freightliner chassis which I have discovered has absolutely fantastic support. If a part is needed that is not in stock, they can get it rapidly. If it has to be manufactured, that is also done rapidly. Their network is huge. If you look at the Spartan network I think you will find a lot of it is with a Freightliner dealer.
I have known so many folks that break down and spend days or weeks getting repairs due to parts availability, I see that as an important issue. - GjacExplorer III
bobkatmsu wrote:
I thought the same thing.MrWizard wrote:
Until I read this,
I thought he was asking about the basement storage space !
+1 - bobkatmsuExplorer II
MrWizard wrote:
Until I read this,
+1 - 2gypsies1Explorer IIIAs stated, full-timers travel constantly and their RVs are in all different areas of the country - left outdoors constantly. If the finish is taken care of properly they can still look like new.
Neither one you mention has been used extensively so that's a toss-up. Check the maintenance records to make sure they've had servicing done like oil changes. Ask for repair records.
If the Alabama one was used for football games it probably wasn't taken to the coast - most likely, Tuscaloosa or Auburn! :) Go BAMA!!! Tailgating wouldn't hurt it any more than driving it cross-country.
Again, I think it's a toss up until you can compare other things. Storage ways is not your problem. Can you see these two in person? Good luck. - gboppExplorerCondition is the important factor.
- J-RoosterExplorerCheck the maintenance records to see if it has been taking care of.
- MrWizardModeratorUntil I read this,
I thought he was asking about the basement storage space ! - the_bear_IIExplorerOutdoor storage isn't a problem if the MH has been well maintained. Wash and wax every two years and wash as often as needed. Roof, window and seam seals maintenance to prevent leaks.
