MRiley37's avatar
MRiley37
Should I get the extended service plan
3 weeks ago I purchases a former rental class c motor home from Cruise America, Its a 2015 Majestic 30 ft. It has about 113,500 miles on it. I still am eligible to purchase the POWER TRAIN PROTECTION PLAN it cost $1,798 and covers another five years or 100,000 miles. it dose not include things inside but dose include
ENGINE GROUP
All internally lubricated parts. Crankshaft and
bearings, oil pump, fuel pump, internal timing gears
or chain/belt, camshaft, camshaft bearings, valve
lifters, rocker arm assemblies and push rods, valve
guides, pistons and rings, wrist pins, connecting
rods, exhaust manifold, and distributor drive gear.
The engine block and cylinder heads are covered
if damage is caused by failure of an internally
lubricated part.
TRANSMISSION
All internally lubricated parts contained in the
housings and torque converter. Case housings are
covered if damaged by the failure of an internally
lubricated part.
DRIVE AXLE GROUP (FRONT OR REAR)
Drive axle housing including pinion bearings, side
carrier bearings, ring and pinion gears, carrier
assembly, thrust washers, axles, axle bearings,
constant velocity joints, internal joints, internal
transaxle seal and drive axle housing, if damaged
by the failure of an internally lubricated part.
SHOULD I GET IT?????????????
