bsshelby's avatar
bsshelby
Shower unit seperating from wall
I have a 2010 Winnebago Access 31c. The shower unit has come loose from the wall on the hinge side of the shower door. The screws that go through the shower door frame and attaching the shower unit to the wall are no longer holding to the wall. Any experience on a similar issue or suggestions. I have pictures available. Thanks.
Steve
  • Agree with JRandall, especially molly bolt if screws were into hollow of wall.
  • Not sure what the configuration of your shower is, but here are some ideas that have worked before. If the screws were attached through the wall and into a stud...just get bigger screws. Might have to re-drill the shower frame. If they simply go through the wall into the hollow behind it...molly bolts might fix it. Or, the best way would be to drill new holes in the frame and re-position new screws into the wall. Thats a start of ideas anyway.
