Rwake901ExplorerAug 21, 2016Shurflo water pump won't shut off..Installed a new Shurflo water pump model 4008-101-A65 last month. (same brand/model I took out) It worked perfect after I installed it. We never used it until today. It won't shut off. It should build...Show More
donn0128Explorer IIAug 21, 2016You either have a leak or the pressure switch is is not connected or defective.
Related ContentWater pump?Why no hot water?Shurflo water pump issueshurflo water pump upgrade?Water Pump Help shurflo
