Rwake901ExplorerAug 21, 2016Shurflo water pump won't shut off..Installed a new Shurflo water pump model 4008-101-A65 last month. (same brand/model I took out) It worked perfect after I installed it. We never used it until today. It won't shut off. It should build...Show More
lj2654ExplorerAug 21, 2016If you have an outside shower be sure the valves are both off and not on with the shutoff pushed?
Related ContentWater pump?Why no hot water?Shurflo water pump issueshurflo water pump upgrade?Water Pump Help shurflo
