Artum_Snowbird
Aug 21, 2016Explorer
I had a previous unit that used a pressure hose to fill the tank. If a certain valve was open, the tank filled, if it was closed the system pressurized from outside pressure.
If I left the valve in the fill position with the hose off, the pump would never reach pressure to shut off as the water would just recirculate. Maybe that is your problem?
