GPWayne
Aug 22, 2016Explorer
Sounds like your pump needs to be primed with some water. The pump may be sucking air. If it can't pull water from the tank it will keep running and not shut off.
Try taking a fitting loose to bleed the air out.
Works for me. Once you get water in the pump it will work OK and build up pressure and shut off.
(It sounds like it's just sitting there at an idle because it's pumping air not water)
