Branson_N_Tucso's avatar
Branson_N_Tucso
Explorer II
Mar 30, 2018
Shut Flo water pump
Have a 2003 Fleetwood Providence,water pump stop working,after reading it may be a blown fuse.Does any on know where the fuse may be located. Looked inside under driver area with no luck.
The MH is on a freightliner.
Thanks for the help
  • check all the fuses first, check for power at the pump switch, then the pump and pressure switch on the back of the pump
  • Are you sure that the 12v wiring to the pump has not simply come loose? That has happened to me several times.
  • Mine has a fuse holder/fuse in the wiring just before the pump wires are connected.
  • DrewE's avatar
    DrewE
    Explorer III
    You should have a fuse panel for the house circuits somewhere, probably next to or in the same unit as the circuit breaker panel for the 120V circuits. One of those fuses would control the water pump. The fuses in the driver area are most likely only for the chassis circuits.
