It is inside the double pane window. Fixing them is an easy but time consuming project. You have to remove the window so you can open the frame up to remove the glass assembly. I used a razor knife to cut the spacer out of the top and bottom of the glass and use a wire coathanger to pull a rag between the panes. I found Turtle Wax Chrome Polish (in the green container) works well to remove the deposit on the inside of the glass. Once clean, you use "Super Spacer" to replace the top and bottom piece you removed. This stuff comes in different widths. The link may not be the width you need..you have to measure the distance between the two panes and order the correct spacer.
https://www.amazon.com/Black-Wide-Edgetech-Super-Spacer/dp/B00UVUUU5Y/ref=sr_1_1?keywords=super+spacer&qid=1573220572&sr=8-1
You set the spacer in about 1/4" and fill the remaing gap with the proper sealant, also resealing along the 2 edges you did not remove. I did have one glass assembly come completely apart due to the spacer and sealer failing. Did make it easier to clean that one!
https://www.amazon.com/C-R-Laurence-Super-Spacer-Sealant/dp/B006JFKTUQ/ref=pd_bxgy_2/136-4484974-8224667?_encoding=UTF8&pd_rd_i=B006JFKTUQ&pd_rd_r=ab6b6bba-0bfc-4679-b6d5-b337b4295e28&pd_rd_w=IvrR2&pd_rd_wg=MPdrr&pf_rd_p=09627863-9889-4290-b90a-5e9f86682449&pf_rd_r=62R4RXDC144N15H9DNCD&psc=1&refRID=62R4RXDC144N15H9DNCD
While commercial companies tout "argon gas" filling, for an RV it's not going to make ANY difference. RVs are so poorly insulated the efficiency loss with normal air will not be measurable. Just do the repair on a dry day. The spacer itself has some desiccant in it to absorb any stray moisture you trap in the window assembly during repair. Usually the two sliding front windows are the worst as they get opened and closed the most causing the sealer to break loose and allow moist air into the glass assembly. More and more RVs with double pane glass are coming with single pane on the driver and passenger windows because of this. Resealing will cure the problem for another 8-10 years. Double pane are a "pain" but they are even more important in an RV than a house, especially if you camp in cold weather. In your house, you don't sleep as close to a window as you do in an RV and there is a HUGE difference in the cold air sliding off a double pane compared to single pane making the RV much more comfortable.
