It is not the tint, zero chance of that.
Well outlined in post above, no going to repeat good information.
But I would like to add something based on my 45 years in the glazing / solarium business.
I have cut apart and repaired many failed units over the years. The actual cause of the fogging is a failure of the seal between the 2 panes.
I really wouldn't just try to remove 2 pieces of the spacer bar (sorry garyemunson :) ) it is important to remove all the spacer bar, that is completely separate the glass panes from the spacer bar. Biggest reason is it is all old and it is sometimes difficult to pinpoint exactly where the failure is. And also near impossible to properly clean the glass inside. Reusing spacer bar is a recipe for failure. And the stuff left there is ready to fail.
This can be done at home, but I recommend leaving it to a pro.
The glass needs to be completely removed from the spacer bar, very thoroughly cleaned with glass cleaner only, no wax, polish or any foreign substance at all. Now here is the kicker - if the unit has been failed for any length of time, the inside of the glass will be permanently etched from being fogged up. There is a strong possibility that you may have to replace the glass. The etching cannot be removed.
The glass is tempered, heat treated for safety. This means you have to order the new glass. That's a whole other process. Local glass shops cannot temper glass in shop. It requires a special oven to do it.
If you get through all this yourself and still go ahead to do it, you need to have all new spacer bar on hand, be it superspacer or metal. I would match what is there. The spacer bar has it's own adhesive strip for the initial bond to the glass. Once assembled it then has to be sealed around the outside. Polysulphide is the standard basic stuff they use. It's a 2 part seal, mixed together like epoxy and it cures only when the 2 components are mixed. Better sealing is silicone glazing, made for longer lasting applications. Not to be confused with trying to seal your roof with the stuff.... Different application.
I have a friend with a glass line and when I redo a unit I bring it in to his shop and ask him to seal it for me or if I can have at his equipment. It's a special process.
Personally, I would let a pro do it. It is involved and you need to know your way around, and understand how this stuff works. If you leave even one little pinhole in the seal, it will fog up again.
Then there is the obvious. You need a clean environment to do this, without a dust storm blowing by.
Another thing is to be sure the unit is done at your level above sea. Huh? You say?
Contrary to what a lot of people believe, it is NOT a vacuum in there. If you live at 2000 feet above sea level and the shop sealing the glass is 8000 feet above sea level, the difference in air pressure will push the 2 panes towards each other in the middle. Not that much of an issue on small units, but on big ones it is noticeable. We used to order windows from a place years ago. They would come with a small needle sized tube in the sealed unit to equalize the pressure at the destination. It would have to be sealed shut prior to installation.
Food for thought....
