tpcollins's avatar
tpcollins
Slick Stick to clean up their generator slip rings
I'm still having trouble getting my 1995 Onan generator to stay running. It is 20+ years old even though it don't have more the 360 hours on it - don't know if that's a lot or not.
Issue still is it starts but dies as soon when I let off on the switch. Last year I bought a new control board and that worked last year. This year it's the same old thing
I still think there's a potential issue with the birds nest of wiring crammed into the back of the control box. Before I pull it out and take it to a service dealer, has anyone used the Flight System's Slick Stick to clean the slip rings on their generator? My boy is an electrician and he's looked at the schematics and feels the problem is with the winding used for charging the battery when running. The control board monitors that and if not present it shut down. Could be a brush issue,
So is the brush and slip rings the same thing? If so i'll order this Slick Stick first. Thanks.
http://www.flightsystems.com/p-slick-stick.html
  • Mr. Tim,
    USE the genny!!! That's extremely low hours and might be the cause of your problem. I was at a seminar last year and the guy next to me had 7,000 hours on his 20 yr. old diesel genny and it was purring like a kitten.
    You really should use it once a month under at least half load to keep all the parts clean and ready to go. Your average is only 17.5 hrs. a year. We already have 240 hrs. on our 23 month old unit.
    I'm trying to put at least 100 hrs. a year on ours. Ours is scheduled for service every 250 hrs.
    Safe travels,
    MM.
