Edward_75ExplorerAug 13, 2015Slide adjustI need to move my big slide toward the front as it hits door handles when it is going out. It is a power gear and is on a 1999 class a home.It is electric driven. Thanks for any help you can give.
fcooperExplorer IIAug 14, 2015I've done a lot of adjustments on my Powergear slide, and I do not remember anything that can be done to move the slide toward the front of the coach.You can get some documentation from Powergear. Go topowergear linkIn their keyword search box, try electric slideout system. You should see two operations manuals. Maybe this will help.Fred
Related Contentarctic fox slide adjustmentHow to adjust LED headlights?BAL Accu-Slide maxed out on adjustmentSlide-Out AdjustmentSlide topper tension adjustment
