zach477's avatar
zach477
Slide lock won't budge
I really hope the day comes when I stop having problems I need to post about, but until then I'm super thankful for the help I get from you guys.
That being said, another problem has found me.
I haven't extended my rear slide for about a month due the the place I was parked not having enough room. Now I have room to do so, and the thing won't move. My rear slide has the electronic slide lock....a little arm that extends to lock the slide in place when it is closed. Today, when I hit the button to unlock it, nothing happens. Usually there will be lights on the control panel to indicate whether it is locked or unlocked, but they don't light up either.
Engine is running, Jacka are down, coach is level. The other slide works fine. What gives?
