zach477 wrote:
Now it's back to NOT working.
This time the coach is 100 percent level. E-brake is pushed down as far as possible.
I'm so frustrated now. After thinking I had it all figured out, it's not working.
The E Brake--- You just have to push until the speedo cluster E Brake light comes ON. Pushing HARDER does nothing else. Unless the Dash indicator will not come on until you push like crazy. You do not even have to have the brake engaged hardly at all. As long as the E brake switch on the pedal closes the pin switch, systems connected to the E brake will operate. Doug
